I have been running this M.O.O. anti wrap bar for about 2 years now and have had nothing but bad luck with it. I want to know if there is something wrong with the design that is causing the the 2 bolts that attach it to the 14 bolt truss to keep snapping? I have used grade 5 and grade 8 bolts but they always snap. I currently ended up welding the bars on there because the bolt holes dont line up any more (from the bar being bent). I have redesigned this thing a few times but it always ends up breaking and now even the welds are breaking. Does it have anything to do with it not using a shackle on the front end only a slide mount or would it help if I got rid of the hard mounts with the bolts and used bushing style mounts where the 2 bolts are at that keep breaking?
