Do I need to replace the shock brackets if I go from 4 to 2 shocks?
gmck5jimmy
86 GMC Jimmy Sierra Classic
Covina, CA
I am replacing the shocks from old Ranchos to Beilstein 5100s. I currently have two shocks on each side of the front. I see in this form that people recommend that I just go with one shock on each side. Do I need to switch out the mounts or can I just use one of the mounts and leave the other one open? Looks like I’m gonna have to make some replacements anyway, as one of my lower amounts are broke.
The single shock from the factory is actually the further back mount on the frame, and it mounts on the inside of the axle bracket. (So it's double shear), all you need is a new bolt once you get the brackets zapped back together.
Just a bit of a divergence from the OP's question, but could be helpful there too...
Anyone happen to know the lower bolt dimensions for a stock single shock? I assume they are the same front/rear?
Overall length, unthreaded length, etc? Also, same in the rear, correct?
