like anything you have seen or recognize? the axle was in a jeep i heard so can they stay or do i need to shop for parts unknown?i hope its straight so i don't have to go through the last pic.
but i don't want to have six different brands of truck parts to get at every brake change.
this is the reason i never buy a modified vehicle. ya never know what was done.if i can motivate myself, i'll drag the 44 close to it and see what i have.thanks brother, darylI second the opinion of them being early d44 brakets. seen several done that way. Nothing wrong with it.
I am not saying it's wrong, but most times you will see a flange welded and then the backing plate bolted.
To me it makes more sense because a big piece like this could get bent, if it's bolted you unbolt it and replce it.
It's hard to bend a flange.![]()
i guess i should see it the 44 ones fit?cool brother.so what caliper do i get?i guess i should see it the 44 ones fit?
e brakes or wheel chuks are good.
i did have it running good ,such as it was. one more try i think. RAAAAAAAAAAAAAAAAAAAA and then i get a new kitchen.
