Anyone here tried using just one good sized battery,instead of two "normal" sized ones?...
I've started my Suburban up with one battery even on some 30 degree days and had to crank it over quite a bit and cycle the glow plugs a few times,and it didn't seem to slow down while cranking it...
I am probably going to need batteries for my pickup,however I am not rich and dont have 200+ bucks for 2 batteries,and the truck needs other repairs the money would be better spent on also..
I see Walmart has a group 24 Marine starting battery on sale for 60 bucks,it has 650 cold cranking amps and an 80 minute reserve,a bit more than the normal sized group 74 my truck would use originally they sell that goes for nearly 100 bucks...it also has both posts and stud terminals,so my cables would be easy to adapt (it has side posts now,and if I put my Suburban on the road,it has top post cables,so the batteries could be swapped between them easier)...
The marine starting battery I realize is probably more a deep cycle type than a "normal" battery,but I've used them before in a vehicle with no issues...they have only a one year free replacement warranty,but so does most other "regular" batteries that are priced at 100+ bucks or slightly less at other stores,so thats not an issue with me--...if I had too,I'd buy two of the marine batteries and spend about what one "normal" battery would cost..
But if one would get me by I'd rather just buy one and not spend double..
Another option I thought about was I can buy a used 4D battery from a semi truck,and mount it under my toolbox in the bed--I can likely score one cheap for core price or a bit more,at a place I know,often truckers will replace ALL the batteries in a semi that uses more than one,when just one of them goes bad,and the others get scrapped for no good reason..
..also the sending unit I transfered from the original tank is junk,so the gas gauge pegs at 3 o'clock and stays there...
...but the amount of money to get a cycle or trike and insure and register it would be more than getting one of my vehicles put back in decent enough shape to trust again...
