Do you run all conventional or synthetic oil in the k5?
Once the lobes have "worn in" it's of no benefit to add zinc, as the lobes are harded.I've never used synthetic oil in any of my vehicles..
Reason being,they all had at least 100,000 miles on them and who knows what was used in them previously--most likely not synthetic..any wear or damage was already done,so why pay more for synthetic that may well end up causing issues instead of preventing them in a high mile engine..?..
They say synthetic wont cause a high mile engine to start using oil or leaking at the seals,or loosen up sludge,but in my experience I have heard and seen too many instances where it did just that to believe it..
Old engines with flat tappet cams need oil with high zinc ZDDP content and most oils sold today don't have enough,even synthetic..the engines now have roller camshafts that don't need ZDDP as much--only some diesel rated or racing oils do have enough of it to keep the cam lobes from wearing down rapidly...so you must use an additive if you use anything else..or risk losing a cam lobe...
I use conventional 15W-40 diesel rated oil in everything too,including my small engines..
Now if I had a new or late model vehicle,I'd be more likely to use synthetic..and lighter viscosity like 5W-30...none of my current vehicles would last long using that though!..
