dodge d60 front
onetonbb74
On the rocks...with a twist
BFE
I have a 1990 Dodge Dana 60 front axle. Kingpin style, Single Rear Wheel (not a dually front axle), 3.54:1 ratio open differential, 35 spline inner shafts, 30 spline outer stub shafts (stock), passenger side drop, complete from hub to hub. Internal locking hubs (Warn). Needs brake rotors and pads, but everything is there, spindles and bearings are good, no scores. Comes w/ a tie rod and steering arm. Not a Dana 61. 67" wms.
$ 900.00
local pickup only, or gas money to deliver...
ttt, I have both ground down calipers and brackets or normal ones if your interested in running 15" rims...
Pictures:
