Dodge D60/SRW 14FF/ORD X-over
OL14BLAZ
TEXAS, USA
Dodge Dana 60 -- This axle came out of a 1991 SRW Dodge 1 ton truck. When I bought it it had a bad bearing hub (spun the race,one hub is still good), spindle and outer stub shaft was bent. I bought a set of dually hubs for it, a good used spindle and a good used stub shaft (stock 30 spline). I have also tore the axle completely down, cleaned it up and primed/painted it black. I have everything needed to put the axle back together except the master install kit, brake parts (capliers, pads and rotors) and lockout hubs. All the rebuild parts are new and still in the orginial boxes. SOLD
GM SRW 14FF -- This is out of a 78 3/4 ton GM truck. It's been shaved (not much) and the spring perches, shock mounts and drum brakes have been removed. I have everything needed to put it back together except the brake parts (rotors and caplers/pads). Like the d60 above everything is new and still in the orginial boxes to put it back together. I also have DIY spring perches and shock mounts for it. Plus a good used 4.10 R&P, used open carrier and ruffstuff disc brake brackets. I would take 275.00 for everything.
ORD X-over parts -- Passenger side x-over arm, draglink with ends, arp studs for arm and 1.5x.375 HD tie rod (no ends). SOLD.
I'm located in Longview, Texas (2 hours east of Dallas off of I-20) and my zip is 75605. I can ship the ORD parts, but have no way of shipping the axles or hauling them (I don't have a truck at the moment).
Eric
Send a pm and leave a number if you want to talk about anything I have for sale.
twoslo4five0 said:
are you intested in parying out the crossover stuff???i dont need the 60 arm..
Do you need the arp studs? I would take 250.00 for everything else minus the arm and studs.
Eric
twoslo4five0 said:
what does that include...i dont really need the ends (i know it all stays togher) but does it include a 2wd box also??
Draglink, ends for the draglink or tie rod (only 1 set, but will work on either) and the HD tie rod. I do have a 2wd box that I could throw in the deal, but it needs a seal kit.
What exactly do you need?
ah yeah i cant use the hd tie rod because its prolly for a 60 and the taper will be wrong on my knuckls...i only really need a 2wd box and draglink minus the ends...i understand you prolly want to keep this all togher so i will understand if you dont want to part it all out..
x-over parts
I am interested in your cross over parts if its not sold yet. I also need the steering box. Put me next in line. Thanks
I will let you know if the other guy backs out.
The crossover is for a 60 I assume, if so how much would you want for all the crossover stuff shipped to 95616?
If buckmtn decides he doesn't want it your next. I just sent him a PM with the total with shipping, so we will see how it goes from here.
Pic of X-over parts
FYI--I will be out of town for the next 8 weeks and will only have none to limited access to the internet during the week. Will be able to check the site only on the weekends.
