Dodge dana 60 help
bigchief427
martinsville indiana usa
Hey everybody new member. I've got some questions about my dodge dana 60. Its an older 60 out of some military vehicle. 1 The spring plates are they different than gms plates, it seems to be hard to find dodge 60 plates and gm plates are easier to find. 2 i 've done searches and real a lot about the springs and steering arms, WILL the steering arm bolt. I would appreciate any help i can get before i get the sob under the truck to find out whether stuff will work Thanks Matt /forums/images/graemlins/truck.gif /forums/images/graemlins/truck.gif
spring plate should work on the drivers side. on the pass side you need a DODGE unit. it has narrower bolts into the housing. steering should hook up ok. you need to put spacers in your shackles to even out the width of the dodge spring perches, they're like 1/2" wider.
