Dodge Dana 60 Kingpin Front Axles OHIO
78Buford
Ohio
I have two of these.
Complete, lockout hub to lockout hub.
Passenger side differential.
SRW (Single rear wheel) axles.
4.10 gears
35 spline inner axles/30 spline outers.
Lockouts work.
U-joints are tight.
Kingpins are tight.
Steering is tight.
1 tie rod is slightly bent. This can easily be straightened.
1 tie rod is perfect.
Rotors are very thick and clean.
The OEM studs & nuts that are in the passenger side of the differential are in good shape.
Both of these were removed from low mileage 1992 model Dodge 1 ton 4x4 AEP/Coal trucks with gas engines on 1-19-2008. These are the most desirable Dodge D60's produced. Why do I mention that these trucks had gas engines? Because most (if not all) of the diesel trucks of this era had undesirable Dana 61 front housings with 3.07 gear ratios’s.
These axles have the internal lockout hubs (like a Chevy or Ford), and they are much beefier than the ‘94 & newer Dodge unit bearing Dana60's. I assisted in removing these axles from the trucks. Both axles are in very good condition. The pictures of these axles were taken on 1-19-2008:
Direct link with the pictures loaded:
http://ohio4x4.fourwardmomentum.com/...ead.php?t=5657
Individual picture links:
http://i47.photobucket.com/albums/f1...d/IMG_3295.jpg
http://i47.photobucket.com/albums/f1...d/IMG_3296.jpg
http://i47.photobucket.com/albums/f1...d/IMG_3297.jpg
http://i47.photobucket.com/albums/f1...d/IMG_3298.jpg
http://i47.photobucket.com/albums/f1...d/IMG_3299.jpg
http://i47.photobucket.com/albums/f1...d/IMG_3300.jpg
http://i47.photobucket.com/albums/f1...d/IMG_3301.jpg
http://i47.photobucket.com/albums/f1...d/IMG_3294.jpg
Price of axle w/ slightly bent tie rod: $700.
Price of axle w/ perfect tie rod: $750.
Payment: Paypal in advance of pickup or cash in person upon pickup.
The axles are in the bed of my truck and will be easy to load into your truck/onto your trailer. I will not ship these axles, please do not ask. I would deliver the axles up to 100 miles from my house for $1.75 per mile (one way). I would deliver only after being paid in full for the purchase price + delivery fee.
Thanks,
Roy
diesel or gas has nothing to do with it being a 60 or 61. I have had 3 dodge trucks of that era with diesels and all had 60s. I have actually seen more 61's in gas powered trucks than diesels. anyway bump for ya on a good deal though.
35dp: Thanks for the info. I'm not a Dodge expert by any means. I would assume though that Dodge did not sell a lot of small block gas engined one ton trucks with 3.07 gears.....but hey, it is Dodge we are talking about. ;)
Sale pending (awaiting a paypal deposit this evening) on the D60 w/ the bent tie rod.
Thanks,
Roy
