dodge dana 60
thies
Registered Member
alaska
found front and rear dodge 60's for a 100 bucks and couldnt pass it up,what will i need to put them in my 90 k-5? I know the spring purches are different and im already going crossover. what else should i look for. the axles are from a '78 i believe or around the year. thanks chris
Small changes up front. Perches aren't really enough to worry about, shock mounts will have to be changed, brakelines not 100% sure if they will bolt on, should since they are the same calipers as GM60s, u-joint is different, might be able to get a conversion joint, steering is done since your going crossover.
Rear will probly need perches relocated, u-joint, and shock mounts. Not much to a rear....
