handloader90
Building!
Swapped a TH350/NP205 in place of a clapped put TH400/NP203.
The 205 originally had the L shaped bracket deal bolted on the passenger side with some bushings and a bracket that went to the frame rail.
The 203 had a rod type bracket that ran from one of the passenger side bellhousing bolts and bolted up on the passenger side of the case.
I don't have room to install the 205's original bracket (exhaust is currently shoved over there).
The 203 rod style bracket is too long, the holes in the bracket are nowhere near the holes on the t-case.
I thought that at some point the 205 didn't even have holes drilled for any kind of torque mount?
Am I safe to run it like this?
