Does anyone know the length for a "short belt" ??
jt512
Maryland
86 K30 454 has the factory serp belt on the crank, water pump, alt, and smog pump.........no smog pump now .......anyone know the length of the belt Now needed by chance? IIRC the factory belt is a 56" 6 rib belt.
you could use a liece of string and mock up a belt length that way and run it like you would the belt and measure it.
That's what I ended up doing, I was just hoping someone might have known the size so I could hit the parts store on the way to the shop instead of running out for just a belt :D.
It seems to be 51", I picked on up on my way home and will check it tomorrow.
