hidesertwheelin
front axles so I can run 15" wheels? I need to replace the calipers anyways when I am swapping the axles over. If someone made some that were already ground down, that would be swell.
1/2 and 3/4 ton use same basic caliper . just the pistion little bigger on 3/4 ton . and rotor is 1" bigger in dia basicly .
there is not much to grind off to clean 3/4 ton with 15" steel wheels. with 4.25-4.50 backspace .
if you have not got rims yet just order 3.0 -3.5 " backspace.
