does anyone make headers for the 6.2?
jp0863
clovis, ca
i need to do some major exhaust work on mine, seems the military boys do some bashing. was thinking headers with cheap-o pepboys muflers would work cool.
The Hummer's ran headers on the 6.2. I have a set but haven't bolted them up yet. Kinda hoping to turbo it instead which would make them useless to me.
Rene
If you ever need to unload those hummer headers, let me know /forums/images/graemlins/deal.gif
hmm, happen to know a few guys at the local gaurd repair depot,,, thanks.
Stan's Headers use a tri-y setup, and they are nearly $500 a pair. That's the only commercial option. Hummer headers are the only other alternative that I know of, but they do require some slight modification from what I'm told.
They're brand new...never been run on anything. /forums/images/graemlins/waytogo.gif
Rene
[ QUOTE ]
[/ QUOTE ]
Yep. Stan's Headers are the only mfg. still offering 6.2L headers. They're a true equal-length header design IIRC. The Hummer headers aren't equal-length and aren't like high performance headers, but probably flow better than stock exhaust manifolds. The Hummer headers won't be a simple bolt-on installation, however, due to the fact the outlets will be pointing down onto the c/k series frame rails. Modifications will be necessary to make them work.
I wouldn't spend the money for Stan's headers. I would use that money for a turbo. If you could find Hummer headers cheap enough, though, that might be a good project to try out.
Casey
The Hummer headers I have, the passenger side exits almost stright out the back of the header just like the factory 6.2 manifold. The drivers side one is almost a center dump, also like the factory manifold.
I haven't fit them up or run them yet, but it doesn't look too terribly hard to make them work. /forums/images/graemlins/dunno.gif
Rene
