The engine is not original to the truck,from what I was told it was a salvage yard used one with about 80K on it --I've put maybe 15,000 on it in the past 16 years..it sat a lot in the past,I had other vehicles and used it mostly to take trash to the dump,and plow my driveway..only the past 6 years has it been my daily driver--and I don't go far with it..
The fuel filter on it was new when I got it and I was lax about replacing it,figuring the low amount of miles I put on it yearly and the size of it wouldn't require it to be changed (wrong !
)--this resulted in it plugging up one summer day 15 miles away,and a $100 tow was required to drag it back home..
I cut it open and it was nasty inside--can was rusty,and had about 3" of sludgy muck in the bottom..learned my lesson not to wait so long..
I have since replaced the filter twice,(first one I doubt was dirty,only had a few thousand miles on it--the electric fuel pump it had that was added near the fuel tank had died and led me to think the filter may have plugged up,but it was no different with the new filter..So I kept the first filter as a "spare"..
Replacing the electric pump cured the issues it was having..engine still has a mechanical lift pump too,and it is still hooked up..never tested it to see if its pressure is good or not though..doesn't look original,may have been replaced before I got the truck..
I assume its working OK..
The fuel tank was replaced about 5 years ago with a clean used one from a gas powered truck,the sending unit some was nice & clean,so its not like the tank is delivering crappy fuel or restricting the flow any..I ran copper tubing from the tank to the firewall filter,and used only short rubber sections to join it at each end..however ,the fuel lines from the lift pump to injector pump are rubber and I've never messed with them..probably should replace them just because they are so old..but the engine never acts starved for fuel,even on long uphill wide open pulls..
I'm avoiding messing with the injectors because of rusty injector lines that will likely not survive being removed..though I have a good condition spare set from a CA member here and another set on a parts 6.2 that snapped the crank (that are about as rusty as the existing ones),I'd rather not start disabling the truck now,when I need it most to plow..
The engine starts with 1/2 a turn when hot,so the IP should be fine..
It's getting the pig to fire up when its below 30*F that is a pain..
Since it has always run this way more or less,I hope to be able to put off doing any repairs till winter is over..
Meanwhile I'll keep using the additive--I got 6 bottles of Stanedyne fuel treatment recently ,have yet to add any--previously I used the Power Service & Howes Lubricator ,and some Solder-Seal Fuel Oil Conditioner,which seemed to make the biggest improvement..unfortunately that stuff hasn't been made in years,I should have bought the whole case of it I saw at the flea market instead of only 2 bottles of it..guy was getting $1 each for it..was dumb not to buy all 12 bottles..
I changed the oil last week to 15W-40,and thought about adding some Marvel Mystery Oil to the fuel and crankcase--it thins the oil some,which wont hurt,but last time I added some to the fuel during the winter it seemed to start harder..the flash point on it is higher than most motor oils..was going to get 5W-40,but I couldn't justify using full synthetic in it for nearly $50 when I already had the 15W-40,and I'm leery of switching to full synthetic in an old engine that may not like it much..I'd rather put the $50 towards new batteries instead..
