DOH!! Q-jet problems.
Brocky
St.John's Newfoundland, Canada
After reading articles on these for the last few hours, I realize I am an idiot. :haha: I removed a screw my buddy had tightened all the way down on my carb. Well he is the idiot. It clearly states not to remove it. Now I need an idea on how many turns out it has to go. Anyone? Its the primary adj screw in the center on the bottom of the pic.
Didn't respond earlier because I thought someone with more experience would respond, but to bring it up top and maybe give you something to start with, I believe that is the APT, or adjustable part throttle.
I'm sure I've read a couple of posts on here regarding how some have set it, try doing a search for it.
Your not supposed to touch it , but I touch mine . All I can say is in my case , it was shipped 2 turns out ( online shows most of the aftermarket ones are ) , I pass emissions with it 1/2 turn out , and run like a hot rod at 3 or more out .
Currently my setup is a good compromise at 2 3/4 turns out .
Without knowing your complete setup , its hard to say exactly where to put it .
You could try to set it as few turns out as possible , and if it has a flat spot off idle , open it more .
Now its easier to adjust if you drill the casting in the airhorn , and add a pipe plug if your carb isn't already equipped .
