I've had the K5 back to its usual business of exploring, but now we're stuck. The inner starter bolt is broken off in the block. My hope is to do the thread repair at home (about 40 miles), instead of performing an extraction on this dirt road.
Any tips? My plan is to shove another 3/8 5" bolt into the hole to prevent the starter motor from turning the nose away from the flexplate. Maybe work a jack or prybar against the starter to keep it from lifting off the block and try for a start.
I don't want to tear up the teeth, so I may give up soon and call roadside assistance. If they can't get here, I have an assistant on the way and it would be a very short pull.
. pry bar using exhaust manifold and jumper the solenoid with pocket screw driver, key on.
