Dome light harness routing?
formercruiserhead
southwest michigan
89 k5 blazer. Putting it all back together, new tub and alot of parts that I don't remember where or how they go. Where does the wiring harness for the dome light go? I know it ends up somehow on the B pillar behind the driver. However not sure if i have to snake it between the sheet metal or does it come out of the hole in the center of the roof in the hardtop jamb?
It actually comes out on the A pillar between the hinges and good luck getting all that fished out
It comes out on the B pillar on pickups fished between the sheetmetal. On a Blazer, try fishing a baling wire between the dome light and drivers sun visor opening. Then, another one from the visor opening down the A pillar.
Then you can use the stiff wire to pull the electrical wires.
