My passenger side is a single white wire that goes to the light under the dash, and grounds to turn on the underdash light, and both dome lights. The driver side has a single tan wire that goes behind the fuse block, and I assume somehow to the headlight switch. I can turn on the dome light with the HL switch, but the tan wire has no power on it so grounding does nothing. The switch is good. I can solve the issue by running a wire from the passenger door jamb switch to the drivers door jamb switch so either one will ground and the lights should work. OH, Auto Zone Duralast door jamb switches will NOT work in an 87 Blazer. The threads are different.
