Don't want a Deckover, wider then standard, check this out
wayne
3/4 ton status
Carlisle, Pa
I am going to order my trailer soon. I did some searching and a freind showed me these. I went and looked at a 7k one that was in stock locally and plan to order one in 10k soon. They are 102" wide with drive over fenders.
More info can be found here. http://www.pj-trailers.com/detail.cfm?ID=B5
I used a trailer like that one time and it was nice... it was wider from the fenders to the tounge but not behind the wheel wells... cool to see you can get them full width the whole length.
I custom designed one and had it built by Carson trailers in Ca. I did not have the time to build it and pack for moving. It is 102" x 24' with drive over fenders. 12,000lb GVW, 2-5/16 ball. I added 2 boxes to the front with rails for tying my motorcycles and fuel cans down. Built a receiver on the front for a removable winch. Now they sell it as an available model.
That looks like one sweet trailer. Mind if I ask how much that goes for?
I am ordering a 10k 18' one. I optioned it with a 2 5/16" adjustable coupler, 2 5,200# Electric/spring axles, 6 lug wheels with heavy duty tires (forgot exact size), 16" on center crossmembers, and power coat blue for $3200. I should have it in about 4 weeks after I order it. I am planning to order it next week. And, yes, they are sweet. It should last me a long time. The place I am getting it through has been awsome to deal with. Their customer service has been great.
http://www.fayettetrailersales.com/
You fit inbetween the wheel wells?
I believe he was ordering a trailer with drive-over fenders and a wide deck (link in first post). Mine doesn't fit between the fenders on my trailer, so I just cut out the inner part of the fenders.:D
Thats what I did with my CJ7 on full size axles. Just fit the front tires, but rears wouldnt fit between the trailer tires. But, if I parked it with the rear tires JUST behind the trailer tires... I was good. Blazer wouldnt work like that though.
My trailer was already 79" between the fenderwells, so it's been fine since I cut another 4" out of each fender. That leaves me a little wiggle room, and the tires only hang off a couple inches.:D
