Door ajustments
ummm, in what way? :rolleyes:
always align to known good points first.. qrters and rockers usually... than fender to the door...
aligning in/out adjustments, bolt's into the doors, is easy peezy and can be done fully assembled...
if you have angle, not straight on the rocker issues.. you really need to pull the fender... those are the ones that go into the cowl, and one from under the dash.
all this is assuming your hinge bushings are good..
