Ok, so my 94 blazer has bad door hinge bushings. They were replaced around 90k ago by a body shop, but its past time to replace them again. The door droops about 1/2 to 3/4 of an inch at teh body line when about to latch. Shop charged $120+ to replace a $4 part, and i was wondering if i should take a crack at it this time.
Granted my 94 is a little different, i took a look at the tech article on removable doors. It shows unbolting the hinges from the doors before removing the hinge pin. is this the way to do it? How heavy will my door be? Any trick ideas for holding it up while removing, besides a couple friends? I don't plan to do this alone, but also don't plan on having someone hold it on their own.
When i get the pin out, are the bushings pressed in, or what? Is the standard "Help" style door bushing repair kit from kragen (shown in tech article) the correct bushings/pins?
Any other insight? Thanks for the help, sorry about the longpost!
. a rope from the ceiling or engine hoist make it really easy. a few jackstands with towels on top of them (to protect the door) work well, too.
There are also some pin retaining clips you'lll want to replace when you go back together. I usually just use a big pair of channel locks and a socket to press the bushing back in while the door is resting on a floor jack(someone holding the door makes it MUCH easier). Use the flat side of the channel locks to squeeze the bushing in while the socket sits on the hinge over the bushing hole(socket needs to be bigger diameter than the bushing).
