It will bolt up and work , there are some differences between the door such as glass thickness and different door panels, but from the outside they look the same.
I have an 87 door on my 78, as said you can’t tell from the outside but the holes behind the door panel to reach in to the regulator are different as are the holes for trim and door panel attachment, all of which can be made to work though
