Door Glass Installation question
bavarian_blazer
Bavarian Forest National Park, Germany
Hi,
I got a brand new door glass and a brand new glass channel but I do not know how I should install the channel on the bottom of the window:crazy:.
LMC is listing some kind of adhesive (only) for the pre 80s trucks in their catalog, so I suppose the later model windows are kind of glued in or so... here are some pics of the problem:
use primerless autoglass urethane(betaseal 418HV)...or any other primerless automotive urethane will do the trick. once you set it leave the window up for a day, then your good to go.
grif
I used the same webbing that they where installed with from the factory. Got it from the auto glass shop. It's like the stuff uesd to hold the vent glass in but wider and thicker. I would think you could use a urethane with no problems.
