Door Lock / Hinge Dissembly
dhcomp
1 ton status
Truckee, CA
Ok, 2 questions, but both door related.
First:
Door hinge pins. Replaced the ones on my 94, and had to compress a spring for the door hold open. How does that older style work? Need to remove anything before I support the door and pound the pins out? Planning to replace pins and bushings to cure sagging doors, as well as install new strikes.
Second:
Is there good dissembly instructions for the door lock mechanisms somewhere? I have a MF'er of a rattle in my right rear door, and need to completely take apart the lock setup, and figure out wtf is loose. If I tap the door skin with my fist, i can hear something rattling inside. I've taken the door panel off, and haven't found anything too easy....
Thanks guys!
