Door locks just click??
85mudblazin
Austin,TX
well after taking my doors off and putting electrical connectors on all the wires when I hit the door lock switch it sounds like a relay is clicking right behind the gas pedal, do both doors have to be hooked up to make them work?? I would see if the window works but the motor is gone in it.
Thanks
-Chris
I haven't gotten around to hinge pins yets , but I did do my electrical already on the doors , bullet quick connects with heat shrink ends .
I no for a fact , that with the passenger door on alone , the locks worked on that side . I started reassembly on that side .
I also know for a fact that none of my door windows worked until I had both doors connected . I finished on drivers side :k5: :k5:
