Door panel diferences
diablo1
colorado
Do you guys know if there are differences in door panels?
73-75 K5 verts to 73-79 K5, Subs, and PU's?
I don't know much, I do know that during the late seventies, GM went to the "tall trim panel. The doors are different too. That is the major change. As for the different trim levels of the trim panels--I don't know.
AFAK, the blazers, subs, and pickups used the same panels. There shouldn't be any changes to the 73/75 blazer's panel even-though the door are cut. Where the doors are cut don't affect the panels although there are caps where the window frame used to be.
You have to watch the regulator, Somewhere i think around 76? the regs. for manual windows at least changed, the rollers are larger and the shaft sticks out farther from the panel.
My 74 panels is physically smaller for new door shells and the plastic anchor holes in the door dont get covered by the stock 74 panel.
