blazininthe73
After finally getting most the exterior of my blazer nailed down I've run into a snag on the interior. I had a body shop do a full restore and paint on the body. They had to use a donor door because the original was in bad shape. At first glance both doors look the same but after a closer look and trying to mount the interior door panel, they are different. At this point, I'm not sure what to do. The body work was done years ago. The original door is in the second pic, from 1973. It seems I would have to get two different interior door panels if I left these doors on there uncut.
Anyone have any thoughts or suggestions? Can you identify which year the door in the first pic is from? Could I cut slots on the bottom angled section of the door in the second picture to match the door in the first pic?
