Door removal mod question
firemedicsafd
Professional Murphy magnet
St Augustine, Florida
I want to do the door mod found on here in the tech section but I have a question. If anyone has done it before, how did you make the wiring quick removable? I don't want to make each wire its separate set of connectors. Id like to find a plug that will fit there and either screw or mag lock together for when I put the regular doors back on. I also have the window motor relay mod so that increased the wire loom to approx 8-10 wires going thru the rubber boot between the door and truck. any help would be appreciated. TIA!
