Ok I got a door to replace my damaged passenger door, but realized after I bought it the lower portion has rust on both inside and outside. The door that my 75 originally came with has a speaker hole cut in the bottom of the door, has a crack on the outside above the door handle, and where the hinge bolts to the door is all cracked and messed up.
Which door will be easier to repair?
