at the body shop i used to work for, we fixed my sagging door on my camaro by getting a 2 foot 2 x 4 (around there it does not have to be exact).placed one end of the 2 by on top of the door stricker.put something into the door latch that is a pretty good fit. place the middle of the 2 by under the object, and lift from the other end. it was not a permanent fix, but it lasted for about 1 1/2yrs. before it started to sag. be careful do not over do it. i also replaced the pin gromets in an 94 blazer. all we had to do to the 94 was brace the door, remove the spring and the pins, replace and put back. it took us bout 2hrs. to do the first door and 30mins. to do the next. be very careful taking off the springs so that they will not come back and get you.replacing the grommets fixed his door sag.
walrus101
goo goo gaju
