door seal hack. cheap fix!
Vombrown
Mountain Man
Great Falls mt
So I have done this with nearly every square body I hAve ever had. Figured i would share it with you guys as I went and picked up another set today.
Any later model minivan with the sliding doors will use a seal that is a perfect substitute for the door seals on our trucks. Some of them will need to be pinched a little but with the glue in the channel its perfection. I picked up two today for 5.00 from the local yard. It will need to be trimmed as its slightly too long. Otherwise its a great thing. Especially at 1/10th the cost of a gm door seal.
What year/make mini-van worked for you?
Sounds like a cost effective solution. Good timing since I'll need some seals soon myself! Thanks.
Pretty much any 2000 and up minivan will use them. Most every square body that I have ever seen needed door seals. These are great seals. Nice beefy bulb seal.
Took some pics for you guys. Seal profile is nearly exactly the same. The factory uses silicone on the top of the seal channel. I use it all the way around. Save yourself some headache and locate the joint in the front kick panel. Just don't cut it too short like I did. Ha!
This is also a good opportunity to clean out that seal channel. I'm sure its crusty with dirt and crap.
