kitasjimmy
Registered Member
I need manual dors instead of electric. How involved is it to install a hand crank & eliminate the motor ect.? Will I need to replace all of the guts?
i was gonna say PM Mike{supreme70} but i forgot you did it a few times yourself Trevor.This must be done in the cold, during a snow storm, and at night with only a mini-mag light. Well it seems thats the only times I ever did it. LOL
drunk friend.
plus when Mike helps me when i get my manual stuff,it will prolly be 10 degrees out.
OH and THAT part.The only time you HAVE to work on windows, is rain, snow, cold or dark. If you have all 4, you will run into problems so it takes 3 times the time.
You just need to swap the regulator. if you look in lmc you can see the pics of them. your crank will come out the power window switch hole. if you wanted to, or cared, you could swap door panels to make it look good.I need manual dors instead of electric. How involved is it to install a hand crank & eliminate the motor ect.? Will I need to replace all of the guts?
not that this window thing was one of them
I love keeping a folder and throwing stuff in it from time to time. Easy look up
