Doors
Muddytazz
1 ton status
Salem, Or.
Lookie what the big brown truck dropped off today :D:D:D
Sorry, crappy cell photo. Will try to get some better ones later.
Now you cant scratch your nads in trafic because every body will see you doing it.:haha:
iv wanted some of those doors from kert for along time but other things need tending to first, i cant tell but does the flat piece of steel follow the body line on the truck or does it just look like it
Its contoured to match the flow of the body from top to bottom. Well it will be once I get the hinges adjusted correctly :doah:
You're right, they look like crap so you should send them my way and i'll take care of them for you.:D Oops, you said crappy cell photo. ;)
I really like how the sheet metal follows the body line. I think that gives those doors just the touch they need.
looks sweet! im gonna order some soon i think once i get settled into the house and all those and a soft topper.. BTW did you fab the mirror mount ? or what did you use?
Yeah, I fabbed my own mirror mount. just bent some flat plate the same as the door skin, countsunk some holes for the tapered head bolts. Then capped off the bottom of a 1" x .120 tube and drilled a 3/8" hole in it. Factory mirror fits nice and snug down inside the tube with a bolt holding it from the bottom.
Sweet! and whats cool, is he now makes rear doors too for guys with burbs...like me!
Yeah I can't wait to get a set for my burb. Probably be next spring before I get them.
