DOT compliant LED tail lights for Chevy's
Musclerodz
Washington, OK
DOT compliant with certificate for hot rods, musclecars, and trucks. I will have these available in the next couple weeks. prices are fairly cheap at $35-$50 per light for brake lights. Not all applications are available yet, but here is a short list of what is. Unfortunately 69 Camaro is not on the list.....yet.
67 Camaro RS brake only
68 Camaro standard brake and reverse
60-66 chevy truck fleet and step
67-72 chevy truck fleet and step
62-65 impala brake and reverse
55-57 chevy brake and reverse
64 mustang brake and park light
67 mustang
plus a few others
Need pics and.....
get to work on 73-91 Blazers.
Please and Thank You.
bluehen said:
Need pics and.....
I will inquire about 73-91 trucks. i have had quite a few interested. Which pics do you want to see?
Mike
Here are pics. Clear not available for another couple weeks. I asked about 73-91, and they have not started on them yet, but they are suppose to start working on mid seventies vehicles later this year.
Are the '69-'72 Blazer lights a straight plug in or will I have to change anything?
wow, looks similar to what I built. I took some 3" aluminum strap 1/4" thick and cut the size of the stock tail light lense then cut an oval in it to use rubber grommet mount trailer LED lights. That way I can go to any parts store and replace as needed but those are pretty bling
they have an 1157 plug so they are a direct bolt in replacement, no modify or hacking to install. Price has been set for the 67-72 lights at $59 for the pair. You can check out these and more products at www.musclerodz.com
Mike
