Thanks, I found most of it. Medical card is required if over 10,001 lb.I was going to call today, but haven't took the time to do it yet. Do you know if you have to keep a log book if your over 10,001 but under 26001 lbs?
I am a Trooper in CO, so I will brief you what CO rules are. Most states like CO have adopted the Fedral laws as they are written. A general rule with most laws, the states can be more strict but not less strict than the fedral laws.
Anything over 10,001 lbs used for business is considered a commercial vehicle and would require a log book or time card.
As far as log books. You do need one if you are in interstate commerce or more than 150 air miles from your business hub. If those perameters don't apply to you, then you need to have a time card proving your hours of duty and your days off, etc.
You need to have a paper log for your current travel day and also the last 7 calender days with you at any time. If you do any type of electronic log, then you have to be able to print it on demand when requested by law enforcemnt (this would obviously require a mobile printer in your truck).
When you apply for a DOT#, your State or Fedral Motor Carrier officer in your area should schedule some type of meeting to make sure you are squared away with all the requirements. After 12 - 18 months of being a carrier, then you can expect a compliance review to be sure tha you are keeping proper records, vehicle maintenance etc.
It would be best to confirm what I am telling you with your local Motor Carrier Officer so that any State specific issues can be addressed.
You can go to
www.mancomm.com and request a Safety Regulations Book to review all the laws regarding licensing, equipment, hours of service, etc.
Again, I hope this helps,
Brian
