trevmountain
In the process of bolting up my new gear vendors I am going to have some steep angles. I am already quite steep with a 7 inch lift I am running now and then to add on top of that I am cutting about 14 inches off my shaft for the Gear Vendor's. Obviously I am going to have some steep angles and I plan to use a CV joint.
I picked up an NP 205 fixed yoke transfer case the other day for parts and bolted on it was a one of these double cardan's. It's right now bolted up for the front driveline. I am wondering first of all what model of CV this is. Is it the 1350? Could it be used for my rear drive shaft. These things are spendy so just wondering if I can use this guy.
