79'K5
Registered Member
Im tryin to figure out how to get the front driveshaft disassembled. Its got the flat ring plate that bolts to the t-case with the double CV portion following that and then the rest of the straight shaft going to the front diff.
They are "Spicer"-type U-joints with the clip on the inside of the Ujoint rather than outside the caps, but i cannot seem to find these clips. it should be pretty obvious i would think but i cannot find them.
im half tempted to stick the thing in out 12-ton press and see if it moves....
and ideas???
and ideas???
