I am looking for a double v belt pulley for my alternator. nothing fancy Just need one.. Oh, the alternator was on a 1985 big block, but that shouldnt matter, I think.
No puller needed on the ones I have worked on. I usually use an impact to take it off cause you have to hold the blade. Most have an hex slot in the shaft where you can put an allen wrench in to hold the shaft while you loosen the nut. Anyhoo, if you have a pulley, that would be awesome.
Thanks,
Mike
