NorthWestFab said:The reasoning stated on 'reduction down the line' is probably where the suggestion came from. Without being re-geared, the 203 and 205 are the same ratio, so given the option I can see why it is suggested to run the 205 in low instead.
Is it going to cause any problem running the 203 in low and 205 in high ? I've never had a shaft broken from *any* use, including 23 spline for my D300 kits. Same goes for ORD I believe.
Like i said, I can see where the suggesgion came from, however I'm yet to see any breakages, so I don't see much reason for concern. If you ran a LowMAX or BlackBox, you'd HAVE to engage the initial range box to take advantage of the varying gear ratios.
-Kyle
NWF.
thanks, thats the confirmation i was looking for
it may eventually get a turbo but we'll see. sounds like i shouldnt have any problems
