I've got a 203/205 doubler with a NWF adapter and the 205 is clocked up I think 1.5" or 2". I haven't been able to drive it for more than a few miles because of fueling issues. Fixed all that and tried to put some miles on it today. Drove about 5 miles and the 203 started puking the fluid. I'm running ATF because I have that weird 205 with syncros. Should I run 80/90 in the 203? Also, the 203 gets so hot that you can barely touch it, but the 205 you can hold onto it and it's just warm. Is that normal?
