Doubler guys
BLZN4FN
Englewood Colorado
I'm building my doubler crossmember what did you all use for the mounts that go between the adaptor feet and crossmember?
Did you use rubber or ployurathane?
I remember someone posting a part number from carquest but I cant find the post.
Here is a pic hope this makes sence.
It doesn't matter what anybody else used, if you have urethane engine mounts you must install urethane mounts at that location also. If you use rubber engine mounts then they must be rubber. If you fail to follow this procedure expect to find broken adapters and or trans or t-cases.
What he said. I broke a trans case......oops.
I have DIY's poly motor mounts. so I guess the question is where did you get your polurathane bushings and what size did you use?
Diy sells bushing kits, called fabricator sets. Just like what you see at the back of the crossmember you posted. I dont care for that design because he is using bushings on the adaptors as well as bushings at the crossmember. I would imagine that allows for alot of movement. Personally I would either hard mount the adaptors to the crossmember then use bushings at the frame, or hard mount the crossmember and use bushings at the adaptors
[FONT=Arial,Helvetica,Geneva,Swiss,SunSans-Regular]What do you all think of this?[/FONT]
[FONT=Arial,Helvetica,Geneva,Swiss,SunSans-Regular][/FONT]
[FONT=Arial,Helvetica,Geneva,Swiss,SunSans-Regular]Universal Mount Sets / IsolatorsMount material is made of [/FONT][FONT=Arial,Helvetica,Geneva,Swiss,SunSans-Regular]HYPER-FLEX™[/FONT][FONT=Arial,Helvetica,Geneva,Swiss,SunSans-Regular] polyurethane, for use as isolator mounts on applications such as obsolete body mounts, kit cars, truck beds, tool boxes and many other similar applications. (See diagram for specific parameters.) Two complete mounts per set- 4 metal washers, 2 metal sleeves, 4 polyurethane bushings. See illustration at left for dimensions.[/FONT]​
[FONT=Arial,Helvetica,Geneva,Swiss,SunSans-Regular]# 9.4101- (shown at left) is best for various applications which require firmer mountings. For high stress parameters such as: off roading/rough terrain racing, drag strip racing, road racing and on extreme-use vehicles.[/FONT]
[FONT=Arial,Helvetica,Geneva,Swiss,SunSans-Regular]Universal[/FONT]
[FONT=Arial,Helvetica,Geneva,Swiss,SunSans-Regular]Mount Set[/FONT][FONT=Arial,Helvetica,Geneva,Swiss,SunSans-Regular]Firm Bushings- 88A Durometer (see diagram)[/FONT][FONT=Arial,Helvetica,Geneva,Swiss,SunSans-Regular]9.4101[/FONT]
[FONT=Arial,Helvetica,Geneva,Swiss,SunSans-Regular]# 9.4102[/FONT][FONT=Arial,Helvetica,Geneva,Swiss,SunSans-Regular]- (shown at left) is best for applications which require a higher degree of insulation. Softer than the bushing set listed above. Universal transmission mounts, motor mounts, cab & body mounts, restorations, "daily driver vehicles", custom body & kit cars. Can also be used for: compressors, tool boxes, generators, independent engines, etc.[/FONT]​
[FONT=Arial,Helvetica,Geneva,Swiss,SunSans-Regular]Mount Set[/FONT][FONT=Arial,Helvetica,Geneva,Swiss,SunSans-Regular]Soft Bushings- 70A Durometer (see diagram)[/FONT][FONT=Arial,Helvetica,Geneva,Swiss,SunSans-Regular]9.4102[/FONT]
That's fine as long as it's the exact same material as your engine mounts. There are different types of urethane so make sure it matches or you're looking for trouble. I would just buy everything from Kert and eleminate the possibilities of any trouble.
