DOUBLER question
muddyblzr
houston/san antonio texas
alright i know dead horse but i found this wms doubler locally and im in real need of one. heres the problem. the doubler is designed to use a ford 205. is it possible for this one to work with a chevy 205? any knowledge would be appreciated
It is for a 32 spline case. That is a ford output that can be swapped into a GM case. If it is the ebay one then also make sure you have a round 6 hole 205.
yup its the wagoneer one on ebay. its also 32 spline. its right up the road from me im praying it will work. if it were clocked flat for a ford what will that do for a chevy?
Fords came w/ a 31 spline, so this one has already been swapped to a GM input. Biggest thing, and its already been said, is you will need a round pattern NP205.
hmm ya ive been told i can swap all the stuff in the ford case over to a chevy case and make it work. im hopin the doubler is clocked correctly and is the right pattern. its right up the road from me
If it doesn't work, sell the parts off and I doubt you'll lose money on it.
