Doug's Headers install
Desert Rat - can you tell us/me what part # header you got?
This is what I did
The power steering bracket is from March Performance pulleys. Its billet aluminum. I had to get a new bracket for the power steering pump beacuse the previous owner mickey moused one on there and it kept trearring up belts and belt would skweak and squeal. I love the bracket, great engineering, perfect fit, and great looks. If you need any brackets I sugest going to them.
Check it out in greater detail: http://www.jegs.com/webapp/wcs/stores/servlet/CategoryDisplay?lang=-1&catalogId=10002&storeId=10001&categoryId=19453&searchItemId=93713
http://store.summitracing.com/default.asp?target=/egnsearch.asp&N=400108
It was the D-300Y-SP-C for the part number on the header. I really like that bracket. One of the issues I've been having is that my bracket seems to be slightly angled causing some squeeling. Muddytazz, where did you get those sleeves and what type of wires are you running?
Resurrecting an old post, I got that power steering pump bracket and it is sweet. Still need to know where Muddytazz got those sleeves.
Glad I could help you out with the bracket. I had the same problem with angled pulley and belt sqeaking, but all gone with the new bracket. :D
