DPI Front and rear bumper w/ tire carrier EBAY!!!! NO RESERVE 9/28
Dang man, as hot as these tire carriers were I thought there'd be a line for it. If I still had my 42's I'd consider getting it back but my new tires wont fit it. Good luck. :crazy:
hmm....im running 42's on stock h1's, but i dont have a body lift. whats the big difference bout the body lift or not? just higher up? does it have a receiver on it? license plate mount?
James, iirc the mounting brackets (1/2" vertical plate) have enough room to redrill the mounting holes if you don't have a body lift. The only difference would be it's moved up a little to accomodate a 2" body lift. The is a place for a tag in the swing down "hoop" but no receiver hitch.
Justin, don't know of anything big going on in July. We will be running a special on humidity, lots and lots of free humidity. :D
the tire carrier can be removed as well, so that it would just be a bumper correct?
Yeah, it'll come off real easy. 2x 1/2" bolts in the hinges can come out and leave only the bumper itself.
hell get me a shipping quote, i guess it has to go on a pallet correct? id have to check to see where a dock is near me, but im located at 22039
