drag link ends...
79k20350
3/4 ton status
Ct
i got a used ord crossover drag link w/ very new ends. the only problem is the boot are torn. can i replace just the boots? any part numebrs? one more thing. ord use tre for there drag links right? or do the use dre for there tie rods? Thanks guys!
i think IIRC if you go to advance auto or auto zone they have one of those bins with boots you can pick though and find some,
but again i cant remember for sure
LUKE
hmm never seen a bin like that:confused:and i do have to stop there quite often:doah:
I think from the post i made to ORD that they are actually TRE's. They are an ES2010R and a ES2010L, i just bought a new pair for my crossover yesterday. I'm not sure where you can buy just the boots but i do know you can get them and i think they are made of urethane and not rubber.
Autozone has them in the help section made from rubber.Also you can find poly.ones but im not sure if you have to buy a whole kit.
hey i know this isn`t under the topic fully but could replacing the draglink cause the front end to be stiffer? wat could a squeaky type noise be from when i push on brake pedal and sometime a grinding or hissing noise when i accelerate a little? also i am having probs with my alternator. mine was making the noise that a bearin makes when it is worn and when i bought a reman alt it did the same noise so i got another reman and it did the same thing??? it has gone away but still does once in a great while. any idea??? info would be greatly appreciated
