mwood1985
i need to correct the steering after a 6-8 inch lift was added. could i get some pics of everyones setup because just the raised steering arm just isnt enough to get it right
Actually the arm is closer to 6" and the pitman arm is closer to 1.5". I have or had both in the past and there was no way they were near 9.5" when combined.If you have a 10 bolt or dana 44 , skyjacker has a 7 inch raised steering arm. Basicly a 4 inch arm with a 3 inch block cast together. If you already have the arm skyjacker has a 2.5 inch drop pitman arm.
anybody got a picture or two of a properly setup 6 inch lift steering?
