Draglink bushings?
chevyfumes
Court jester
- In Memoriam -
Watch for the muzzleflash!
I just adjusted my draglink after my lift and was wondering if new poly bushings would tighten up some of the slop in the steering?Or is there supposed to be that much play in the link?
There arn't bushings in a draglink. The rubber part is just a dust boot. They should twist side-to-side but should not move up-and-down. If they do replace them (and measure the length before you take it apart so you can get it close before you bolt it back on).
