draglink q's
dheavychevy38
Algonquin,illinois
draglink q\'s
if i have a 8 inch suspension lift and run a raised steering arm with a dropped pitman arm can i use a stock draglink?
Re: draglink q\'s
You'll have to most likely put it together and check the total length and the angle... you want the drag-link to be near level, this will keep it from binding on the ends..
Re: draglink q\'s
There is also a drop drag link kit that works with the stock fron-back set up. It is good for about 4-5" of drop. You can also go x-over (a sway bar is moot on an 8" lift).
