Draglink???
camok5
Buellton, Ca
I just put a custom 6inch Deaver spring lift on my blazer, 2 in the rear with a ORD shackle flip. The blazer is my daily driver and I have a swaybar disconnect, the springs are way to soft to run crossover and I have bent drop draglinks before from jumping it. My question is there another option like a stronger drop draglink or maybe a custom pitman arm( I already have a raised steering block)? /forums/images/graemlins/thinking.gif
Have you tried a raised steering arm? That's the route I would try. Then, if you need more correction (which you probably won't) you could try a 2" drop pitman arm. We have the 4" raised arms for $65.00, they're pretty cheap and relatively easy.
I just ordered my drop pitman arm and it was about $90 bucks. Thanks ORD... /forums/images/graemlins/thumb.gif
